RCU Forums - View Single Post - tuning help
Thread: tuning help
Old 03-06-2006 | 10:01 AM
thecool1
Default RE: tuning help
I was having the same problem. so when i adjust the idle screw. i should be able to look in the carb and see the opening get larger or smaller correct? cause it didnt look like it was moving when i adjusted the screw. maybe im wrong...ill have to check again. so mr rpms at idle are way high. do i turn the idle screw clockwise to slow the idle rpms?
