Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
 help with throttle responce/curve >
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 02-19-2011 | 01:26 PM
Default help with throttle responce/curve
i,m new to bigger electrics. been flying gas 40% for yrs tho.anyway i have a castle pheonix 100 and a motrofly 4325-380 turning a 20x10 prop. pleanty of power but heres the problem. the throttle is not linear, not even close as far as i can tell.it seams all the power is in the top 1/2 of the stick. i didn,t measure thrust or rpm but current at full is 94 amps and at 1/2 stick it's just 15 amps. ideas? am i missing something in the set-up or do i just use a curve in the transmitter as i do in gas.
Old 02-19-2011 | 01:46 PM
BarracudaHockey's Avatar
Default RE: help with throttle responce/curve
Did you calibrate your throttle end points? Sounds to me like you did not.
Old 02-19-2011 | 02:01 PM
yes, twice
Old 02-19-2011 | 04:24 PM
Did you end up with symtrical or nearly so end points? I had to do something with the throttle trim on my 11x to get the end points so they were close to the same as each other.
Old 02-19-2011 | 04:48 PM
yes, and low is off and high is full on. but the responce is not linear. i would think mid stick should be close to 1/2 max rpm. it is not.my high end numbers are where they should be far as amp draw and thrust
