Shockflyer Acc??????
#301
NJ
RE: MINI SHOCKY
I went to dinner with some friends tonight and had a few libations. So I came home and didn't feel much like programming so I cleaned the work shop. Just like rain is inevitable after you wash the car, my work bench cant stay clear for long. I grabbed the depron parts I had previously cut for my mini shocky. I also grabbed the digital camera. I snapped a photo of the clock when I started building, 10 minuets till 11 pm. I started by cutting this carbon fiber sheet I just happened to find when I cleaned the workshop. By 12:20 I had the airframe done and the motor mounted. I'll finish it off in a few weeksI will take the tiny servos out of my EDGE and use them on the MINI, I wanted to switch them to HS-55's anyway. I'll have it done soon and let you guys know how she flys.
Whack
Whack
#303
RE: Shockflyer Acc??????
Hey Whack...
Have you seen these prop savers from Aircraft-world? I have been using them for a while now, and I reckon they are the "Bee's-Knee's"...
There are different sizes so should fit the Nippy too
http://www.aircraft-world.com/shopdi...+prop+adapters
#304
NJ
Thanks for the link, I wonder what the shipping costs from Japan to the east coast of the U.S. The prices look great, and they have a great variety. I may try to machine a copy of that.
#305
$2.50 anywhere in US. Great service.
ORIGINAL: whackinski
#306
RE: MINI SHOCKY
I have recieved stuff in 3 days from them!!!!! Although about 7 days is the norm...
The way the dollar is at the moment, I get nearly all of my stuff from them. Only carbon rod and depron I get locally...
#308
NY
Rprop adapter
I got something very similar from Hobby Lobby when i ordered my AXI.
A friend stole it Saturday though to experiment with his GWS as it fits that shaft too. he breaks props in very spectacular ways. We have yet to see if this will help.
http://www.hobby-lobby.com/propadap.htm
#309
NJ
RE: Rprop adapter
Wind what do you think about the Stringfly Mini ShockFlyer? assembled in under 2 hours. I will never pass C++ with all this foam and glue around![:@]
Whack!!
Whack!!
#310
NY
RE: MINI SHOCKY
Cute little mini shockie you have there!
isn't it great how you can lay these planes on top of all the tools without worrying about them getting dented.
No need to ever clean off the bench this way. Well, almost.
#311
NJ
RE: MINI SHOCKY
If you notice the Gulliows rubber powered plane in the background, I may be converting that into RC soon. I have a snow globe car, I'll take the guts out and use it on the plane. I have already harvested a beeper motor from my old pager, I think it's a safe bet they wont come back in style!
I have old Cell phone to disassemble too. I feel like a kid again taking things apart for my own misguided purposes.
#313
NY
RE: MINI SHOCKY
You sound like my project lead here at work. He came to one of our weekly indoor fly ins, and after the demo he said he was psyched to start harvesting lots of little electronic gadgets to tinker with like he did as a boy.
so many planes, so little time.
#315
Standard shocky
Hey guys, cracking thread. On the basis of this thread I bought and flew my first shocky (I'm in London, uk).
A few people asked about std setup, I started with :-
3 hs55's (carbonite jobs)
hitec electron 6 rx
ripmax (rebadged) "12" standard esc
"power" kit (standard 280 motor and gears etc)
I tried with an 8cell 700 mah pack from my gws mustang and soon learned about weight. It did actually fly but it was dog rough. I grabbed some kokham 340s (3s) and tried again, it flew just great!
When the packs are fresh it will launch no probs just let go of it pointing straight up and off it goes. After a while with the standard stuff it's still punchy but looses a lot of the vertical (I am guessing there just isn't the voltage to spin that little 280 fast enough toward the end).
I was always planning on brushless, stripped the little crappy pinion gear tonight (the motor screw vibrated loose) so axi it is, not sure on the esc as yet (castle creations?)
Just thought I woul let you know it flys ok standard, if you keep the weight real low. I now have a stripped down schulze a4 reciever saving me some more weight.
These things are so awesome, everyone in the park comes and asks what it is, where you get them. I should sell em...
John
hitec electron 6 rx
John
#317
RE: Standard shocky
ORIGINAL: pin
I can finally 3D in my front yard!!! Or down the street at the local park, in the school yard while waiting for my daughters softball practice to end, while waiting for Starbucks to finish my decafe latte, .......
#318
RE: MINI SHOCKY
You have to be very very careful...After getting mine built and flown, I bought 3 more.
I'll keep two built and ready to fly, and the other two I'll build when I'm bored as backup ariframes.
I have 3 (although one is 30% larger!!!) ready to fly...
Hey, does anyone know of any other R/C aircraft that has taken the world by storm like these shockies?????
I wander if Martin Muller actually knew they were going to be this sort-after when he designed them???
#320
My Feedback: (24)
RE: MINI SHOCKY
Can't wait to get mine going, I finally have all the stuff on order. Coming from 4 different places of course
Here's my setup
Zivko shocky
Typhoon Micro 6/3D
Castle Creations Pixie 10
HS-55 Servos
GWS rx
I'll be outdoors most of the time so I opted for irate 2s 830s instead of the 2s kokam 340mahs. I also wanted a litte longer flight times. I might try the 340s later down the road.
2 questions...
I'm using GWS slowflyer props, do I need a prop adaptor for the typhoon or can the prop just slip on there?
Anybody turned their typhoon around? I'm wanting to make a rear mount similar to the way the AXI mounts, is it hard to do or is it a better idea to use the front mount method.
Here's my setup
Zivko shocky
Typhoon Micro 6/3D
HS-55 Servos
GWS rx
2 questions...
#321
NJ
RE: MINI SHOCKY
I went flying with Vertical ts last night. I am happy to say that my chunky repaired ShockFlyer still hovers even with all that extra foam and Probond. I will have to build a new one soon. We flew the Formosa under the lights it would totally disappear on the downwind turn in the dark, Fun stuff. I still have a prop issue with that plane and it screams like a cat when you step on its tail. We think there is a gear mesh issue to deal with to boot.
There was no wind at our lighted parking lot last night. Absolute calm, a very rare night, until I started flying. I Lunch boxed my Shocky again, they bounce, did you know they bounce?
These are the greatest model airplane ever.
#323
RE: MINI SHOCKY
I have only been flying for 2 months or threabouts. I picked up an ARC ready II with an mds 40 and some other bits for £50 from a car boot sale. I joined a club and have flown that on a buddy box 3 times. I got bored of driving all that way and got a GWS mustang and started flying that in the park. I smashed that the first flight but learned something about control throws and endpoints.
I have been playing with realflight and g2 for about 2 years, and I have to say that although things are quite different with a real plane, I would say I am a competent pilot already. I then saw the shocky and had to have one, I got a mini electric hele at about the same time.
An old timer saw me in the park and came over as I brought the shocky in, he said I was a very good pilot and was astounded to learn how long I had been flying. I was doing inverted circuits, split-s, cuban 8's, loops inside and out some knife edge stuff and some basic hovering.
I keep having to check myself when I think how much I have learned in the time I have been doing this, a real credit to simulators as a very good way to get used to orientation and stuff. If you mess about with wind and flight failures in the sim it would appear you can handle a low wing or a shocky in 15mph winds
Coompletely addicted now, the other 2 shockys are on order, as is the axi/phoenix combo and some more cells
#324
NJ
RE: MINI SHOCKY
Yeah Pin, I have the Nippy Black which is fine but I must have an AXI. I'll grab one sometime this summer. Even though I bounce my ShockFlyer alot I dont destroy it that often. I like having one that I dont care about, it makes doing low maneuvers that much easier when you have no emotional attachment to the plane.
My goal for later this summer is to have 1 pristine shocky with an AXI setup and one to beat on with the Nippy.
I am totally hooked on electrics. I only started 2 months ago and I already have built 2 foamys, and have 3 shoky kits in reserve, plus my reliable Flitter B. Look for my sale in the marketplace. I'm selling a FlitterB with a GWS twin. Although it wont 3D it flys in really small areas.
LOVE RC FLYING
LOVE RC FLYING
#325
RE: MINI SHOCKY
We should make a shocky site with all this info in it, vids etc and try and organise an owners club thing. Not that I have all that time spare but I am handy with all things computer / internet
