AXI 2208/34 Jeti 8 Question
RI
Is anyone out there running an AXI 2208/34 on a Jeti 8 ECS with a 10-4.7 prop. I just finished installing mine on my shockflyer. When I advance the throttle the motor shakes violently until the motor catches and starts running. I tried advancing it slowly and quickly and get the saem result. I also disabled te break with no change. Anyone have any advice?
RE: AXI 2208/34 Jeti 8 Question
MY outrunners shake sometimes and when they start to shake i just bring the throttle up. Never really had a problem like that. Is there soemthing it is rubbing up against
Dan
Dan
Generally the shaking is the ESC trying to decide what position the motor is in. I also have this happen on my Astro 010 with CC ESC though it's not violent such as you're describing.
I think some motor ESC combinations do this quite a bit, though I'm not sure what combinations those are. Some people have gotten around this by giving the prop a small spin before applying throttle, but this generally works better if you have the brake disabled.
You may want to contact the vendor you purchased this setup from, they may be able to help you cure the problem.
Good luck
Jason
Good luck
Jason
CA
Try a hard start or soft start option on your esc if it has it. I had the same problem with my axi2208/34 & cc 25esc. If you can also stiffen-up the front to stop the flexing this will help a little.
