Ultimate E-3D power setup specs list
NY
It would be great if we had a large list, in one place, of power systems that work for 3D FFF and Depron models.
This would reduce the need to try out 3 different combos before you get one that works.[:@]
So, If you have reliable info Please post it here.
Info should include:
1. Model info, total weight, wing area, pics would be good
2. Motor, make model and winding
3. Speed control make and model and its settings
4. prop used
5. Battery used, make and # cells
6. Amps at full
7. Average flight times
8. Performance, this is subjective of course[:-]
Any other info would be great
4. prop used
6. Amps at full
CA
6mm Depron 3DX, 13 ounces with landing gear
Himax 2015-4100 brushless
GWS D 6.6:1 Gearbox
Castle Creations 25 amp speed controller
Apc 12x6 prop
gws receiver
etec 11.1v 1200ma lipo battery
20 minute flights.
Rare WOT
Unlimited vertical
GWS D 6.6:1 Gearbox
Apc 12x6 prop
gws receiver
20 minute flights.
Rare WOT
Unlimited vertical
3DX 12.2 ounces with landing gear
GWS350D
GWS 12x6 prop
Great plans 12A speed ctrl
GWS Rx
Kokam 1200 3S lipo
6-8 minutes of extream flying 8-10 of easy flying
Unlimited vertical for the first 5 minutes for sure
GWS350D
GWS 12x6 prop
GWS Rx
Kokam 1200 3S lipo
3DX 10.5 oz no landing gear
himax 2015-5400 in GWS box with d 6.6:1 gearing
GWS 12x6 prop
thunder power 1300 2s
C.C, pheonix 10 esc
GWS RX
GWS micro servos
Has unlimited vertical, you cant go wot for more 2 or 3 seconds for it will blow the plane apart.
flight times are around 20 min
GWS 12x6 prop
C.C, pheonix 10 esc
GWS RX
GWS micro servos
OH
Got ya ALL beat!!!
HiMaxx 2025 5300
GWS frame 6.6:1
GWS 12x6
CC 80A(on loan) soon to be CC 25A
Kokam 1500 3S
AUW 18oz(inc ldg gr) with 45+ oz static thrust!!!!
Peak I is 24A at WOT.........................who needs it!!!!
Hovering I is 8A 15-20 minutes hovers/flights no sweat!! Flying around half to 67% power is unconcsious!!! Like it's on a rail!
Jason Noll YX 540T
40" span, 38" long
FMA M5 JR Rx w/ Azarr Lite antenna
GWS Pico servos
This is the same plane that he and Frank are flying in the ETOC!!!!
Verticle drag races are nothing!! I win everytime!
Enjoy!!!!
Chris~
HiMaxx 2025 5300
GWS frame 6.6:1
GWS 12x6
Kokam 1500 3S
Jason Noll YX 540T
40" span, 38" long
GWS Pico servos
Enjoy!!!!
Chris~
