Nippy 0508 doing funny things on my shocky?
I am running the nippy black 0508 on my shockflyer with a phoenix 10 and a three cell thundrpower 720. If I go from low to high stick the motor makes a funny sound and will only spin slow but if I slowly move the stick to high it works fine. I thought it might be that the pack could not handle the burst so I put on a 3 cell 1320 and had the same result. I then put on a 2 cell 1200 and it worked fine but I could not hover it as the rpm was to low. I also put on many differant props from 8-6 to 10-47 and no help. I have heard to many good things about this motor so I hope that it is somthing that I am doing wrong and not a bad motor[&o] Any help you all could give me would be great.
Thanks Mike
Thanks Mike
CA
RE: Nippy 0508 doing funny things on my shocky?
Try entering the programming mode for the esc. Change the soft start setup. I'm not sure on the phoenix 10 as I run the 25's. But I think the programming modes are the same. My Himax 2015-4100 was doing the same thing. I don't think it's your motor. You can always contact castle creations and ask them. I hear they have great customer service. Good luck, Chris....
Thanks I will reprogram the esc and see if that does it. Sounds like a good place to start.
