3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Shockflyer Capacitors
Old 05-26-2004 | 06:43 PM
Default Shockflyer Capacitors
I must have read a thousand posts on the shockflyer and I cant seem to find out where to solder the capacitors to the stock motor. Can some one describe it for me or post some pics? Also, if I get a brushless motor do I still use the capacitors? Thanks for any help, the directions are just too vague.
Old 05-26-2004 | 09:28 PM
Default RE: Shockflyer Capacitors
http://www.rcuniverse.com/forum/m_15...mpage_8/tm.htm
That should do it!
Old 05-26-2004 | 10:07 PM
whackinski's Avatar
Viper use all 3 caps. one cap goes between both motor lugs essentially from positive to negative. place one wire end from each of the 2 remaining caps in opposite motor lugs. finally solder the 2 remaining cap leads to each other and to the outer housing of the motor. I describe this process in detail in the thread Walt listed. If you need clarification post your questions there.
Whack
Old 05-27-2004 | 08:35 PM
Thanks for the info.
