3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Ayuda!!!
Old 08-09-2004 | 07:05 PM
Default Ayuda!!!
hola a todos..
tengo un motor gws eps 300c dx a . y un speedcontrol es el gws ics 300.
en la caja del motor y el speed dice 9,6v- 700mah
Mi pregunta es esta :
? corro riesgo de que se me queme el motor electrico o el speedcontrol. si uso 3 celdas de 1200mah li-ion..
el voltaje total de las 3 celdas es de 10,8 v.
Muchas gracias por contestar
Matias
Old 08-09-2004 | 07:50 PM
Default RE: Ayuda!!!
[&:]Hello matias,
the battery says: 9.6 volt-700 mah, not the ESC
the gws ICS300 wasn't designed for use with lipo battery. Have low voltage cutoff: 4.2 volt
And for use with 3 lipo cells you need a ESC with voltage cutoff: 9 volt. The Castle Creations Pixie ESC is a good option, or any ESC
First, you will damage the the lipoly battery and the ESC: the ICS 300 handle 5 to 8 cells Max. voltage input is: 9.6 volt
Where you bought GWS stuff in Bs. As. ?
Send private message for response in Spanish.
