Li Poly charging
IN
I have a tower hobbies quick field charger and I was wondering if it would be safe to charge ny lipos on it? It has a spot for them i believe. It says Li Ion. Thanks for your help.
MO
If it is the MKII you will have NO problems. I have over 150 cycles through my Li-Pos and the guys I fly with have way more than that on some of theirs......
Just remember green is GOOD!!! If you are charging your li-po's the charge start button must be pressed 3 times and the LED will be GREEN.... any other color and you are going to have a battery swell up..... GREEN IS GOOD, GREEN IS GOOD....
He did I mention that GREEN IS GOOD when charging Li-Po's on the MKII????
Bill
Bill
