Help with Blitz EPP
Im getting a Blitz and i was wondering what everyone else has set there's up like engine,spedo etc? what it flys like? and what mods you have done to keep it from twisting? Also what glues should i use?
NB, CANADA
My friend built a Blade same as the Blitz but with only one wing. When we built it we just used 5 min epoxy and thin ca with zip kicker too and it did not hurt the foam at all. Below is a list of the setup we used on the blade I think it would work fine on the Blitz, it has way too much power for the Blade so it should haul the Blitz fine
Blade setup:
AXI 2208/34
APC 9x4.7
Phoenix-25 ESC
Apogee 3s 830 mah
Cirrus 5.4 Ultra Micro Servos
GWS 6-Channel Naro Receiver
hope this helps,
Brian
Blade setup:
AXI 2208/34
APC 9x4.7
Phoenix-25 ESC
Apogee 3s 830 mah
hope this helps,
Brian
blitz is heavier, and really noes not fin indoor flying as Blade do. you hsould not stiffen it ut, it should be wiggly, that´s the point of epp, crach and it just bounces. Some like it some don´t. I prefer buildt up Depron fulelages...
use medium or thick CA and kicker for all glueing.
