TENSOR 4D HINGE TAPE HELP
NC
JUST GOT THE TENSOR AIRFRAME BUILT AND THE AILERON HINGE TAPE IS PEELING OFF AND WONT STAY ON. IT WAS FACTORY APPLIED AND PAINTED SO I CANT JUST PEEL AND RETAPE. THE PLANE IS BEAUTIFUL AND WAS EASY TO BUILD BUT I NEED HELP, I DONT WANT TO LOOSE THE GRAPHICS BY RETAPING. I COULD GO OVER WITH WIDER TAPE BUT THAT WOULD JUST ADD WEIGHT.
ANYBODY GOT IDEAS..IM READY TO GEAR IT UP AND FLY
CA
Try using a sealing iron for MonoKote type plastic covering or a clothes iron if that's what you have.
The heat sometimes makes the tape stick again.
Practice on scrap foam and tape to get the heat right.
NC
IVE TRIED ABOUT EVERYTHING---THERE MUST BE SOMETHING IN THE FOAM STOPPING ADHESION. IVE HAD MANY FOAMIES AND THIS HAPPEN BEFORE AND PEELED TAPE - CLEANED - AND PUT ON NEW TAPE BUT ON THIS PLANE THE TAPE IS PAINTED OVER. IF I PEEL THE TAPE I WILL LOOSE THE TRIM SCHEME THAT WAS ON THE TAPE
