Shockflyer Duration
CA
Hey i have a shockfler that has stock power.When i say stock i mean STOCK.I was woundering the run time of a kokam 3 cell 11.1 volt 560 mA batt. would be?
GA
I would say roughly about 15 min or so. Bear in mind that with that 11.1v battery, that motor is going to get quite hot if you fly around for 20 min. I would recommend keeping it to about 7 min flights or so, with time inbetween for the motor to cool down.
It should be a rocketship on vertical...
Im running a 11.1v on a GWS 350 in mine, and it has unlimited vertical.
GA
Oh yeah, the battery I was using was a 11.1v 700mah, and it would run for 20 min or so. After that amount of flying time, it would be run down to about 9.6 or so....so you have to be careful not to go too low.
