Shock Flyer Help
CA
Shock Flyer Help
I need help! I bought myself a Shock Flyer and I cant figure out how to mount my Typhoon-Micro 6 motor. The instructions are a probably the worst ive ever seen and their mount is designed for a geared motor anyway. I bought a mount that is designed to go on a stick of hardwood but, I don't see a way to make it work.(It fits the motor great but there is no way to mount it on the plane) Please someone give me some pointers!!!
Taylor
Taylor
OH
RE: Shock Flyer Help
Hold the stick and motor along the top vertical fuse, draw a line around it, and cut it out. I use hot glue but epoxy would work. If your motor came with a radial mount that would be better. I can send a link how to radial mount if you like.
