3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
TENSOR SETUP
Old 03-29-2005 | 09:59 AM
crashburn4ever's Avatar
Default TENSOR SETUP
How would this setup work?
AXI 2212/34
EFLITE 20 amp ESC
Eflite 1200mAh 3s
3 HS -55 servos
GWS 6 channel RX
Please make any changes due to your experiences. Thanks ALOT .......A.J. Vines
Old 03-29-2005 | 09:57 PM
Default RE: TENSOR SETUP
I had a Himaxx 2812 (which is about the same as an AXI 2212) Eflite 20a ESC, TP 1320 3cell and much heavier servos than that, and mine had plenty of power. Make that more than enough. Your setup is perfect.
Old 03-30-2005 | 01:56 AM
My Feedback: (14)
Too heavy in my not so humble opinion...the Tensor thrives at 10 ounces all up...
OK, you asked for changes, here's mine
Eflight- 370-1080 outrunner
Castle creations CC-10
Tanic 850 3sp
HS-55's are fine
GWS 6ch is fine, too.
All up 10.1 rtf..
GWS 10X4.7
Old 03-30-2005 | 10:17 AM
I might get the cc 10 and the 370.
Do I need to re-enforce the fuse because the Torque?
Old 03-31-2005 | 08:10 AM
the lighter the better. I don't normally fly foam, but I do have a tensor. 4.4 gram servos, gws 4ch rx, hacker A20 34S and 2-cell 480 pack, just a few grams over 7 oz. Flew it with the 28M hacker which is a half ounce heavier, with larger 3 cell pack, at a little over 9 oz, and although power is higher of course, the plane flies far superior with 20% less weight and a little less power.
