motor problems
WA
hi
i just bought a new himax 2015-4100 motor and i am trying to run an old version pheonix 10 esc on it and when i throttle up all that it does is jitter back and forth. i already got the motor replaced by MPI but it still jitters. what should i do?
WA
ohh yeah and about that prop, whenever i take the prop off of the shaft the motor runs fine. it is a 12x6 on a 6.6:1 but i got a prop and kept cutting it down until it was about a 2 inch diameter and it still didnt work. but if you spin the prop really fast and jump on the throttle it works fine. do i need soft start? my batteries were fully charged.
thanks for the replies
Rob
Rob
WA
i think i know whats wrong. i talked to a guy at the LHS and he said that it is sometimes the reciever. i thought about it and i remembered whenever i would move the ailerons the elevator and rudder would glitch. i have another reciever so i will try it. thanks for your responses.
Rob
Rob
