3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
GP Polycharge4....
Old 07-21-2005 | 07:50 AM
Default GP Polycharge4....
Great Planes Polycharge4, Does anyone have one of these? If so how do you like it? Thanks.
Old 07-21-2005 | 04:59 PM
My Feedback: (18)
Default RE: GP Polycharge4....
I haven't used mine all that much, but for the most part I like it. I did, however, have problems using it from a cig lighter adapter in the car. I've had no problems using it from my bench top power supply. I don't know what kind of amperage I can pull through the cig lighter in my car and am wondering if the Polycharge pulls too much...
Old 07-22-2005 | 03:43 PM
VIC VIC's Avatar
i'm about to buy that changer but want to hear some coments about it too, before buying it, i read the manual and found that it needs a powersupply that delivers at least 16 Amps in order to use its full potencial. i don't think that you can pull out that amount of current of the lighter outlet of the car, well i assume that if you are charging 4 Lipo batts of 1000mA each at the same time there will be no problem using it.
Old 07-22-2005 | 04:41 PM
I'm not sure about the cig lighter, but I have a 20Amp Tripp-Lite power supply that I use for my Triton that should work just fine. I just want to be able to charge 4 batteries in 1.5 hours instead of 1. That way I can wake up in the morning and charge my batteries and go fly. And when I'm at the field, I won't have to wait for one battery to finish before I can begin charging the next. It sounds like a nice charger, but I wanted to get other peoples opinions.
Jay
Old 08-03-2005 | 12:15 AM
VIC VIC's Avatar
i just got mine, so far it's been doing a good job, i've used it to charge to diferent brand and capacity battery packs with no problems, i'm a little impresed how fast it charge the batts it only takes 1 hour and 20 mins to charge a fully discharged pack that's quick compared to my old home made charger that take 2 hours. there is one LED on each output that indicates the status of the charging process it also indicates how many cells the battery that is plugged has, there is also a sound indicator, it lets you know when the charging begins and when it is done.
Old 08-03-2005 | 12:28 AM
emnm79's Avatar
supposedly the polycharge 4 cuts the packs off early, and doesnt fully top them off, It just cuts by voltage. While you will only lose 5% runtime or less, i'm sure it will keep your batteries working for a few more cycles than fully peaking every single time, and probably helps to prevent overcharging a cell in an out-of-balance multiple cell lipo pack...
