Best Electric 3D Bi for outdoors?
CA
I've been flying a three channel modified elec Piper cub Jr. with great success and would like to get a Bi 3D plane that will be use 100% outdoors. Also want something that will fly slow if I want it too...I have almost an acre with about a 120 foot by 200 foot flying area in the back yard...would like it to be able to handle a little wind.
Like the looks of the Hobby Lobby Quasar?
Also want to keep it lite...recommedations on flight pack?
I also have Real Flight G3....I can see I will need to practice...best plane to practice with? I also have a Hitec Flash 4 FM 72mhz TX...is this going to work ok with this plane?
Ken
Ken
SC
RE: Best Electric 3D Bi for outdoors?
I would say the Yak 54 is the best 3D plane to practice with on G3 for me. And if you want the Quasar here is everything you need:
http://hobby-lobby.com/quasar.htm
KS
The Quasar has very light wing loading. I would think that if you've got any wind, it'll be very tough to fly. I'd try something a little heavier like an Ultrafly bipe or even a balsa plane if you want something bigger.
KS
...Or Hobby-Lobby has
Christen Eagle
Uzi XL & Uzu XXL
There's also the Zoom-Bi
All of these are EPP, making them resilient and heavier, which would make outdoors flying better.
Brad
Christen Eagle
Uzi XL & Uzu XXL
Brad
My Feedback: (39)
AZ
Check out Northest Sailplanes Products at www.nesail.com they have several EPP planes. I just ordered an EPP ultimate biplane from them. They have several planes and one of them should work for you.
Rick
Rick
My Feedback: (13)
MD
The R/C Skydiving.com Pitts it a great plane that handles the wind well. It is worth a look. www.rcskydiving.com
Scott
Scott
CA
What do you guys think about this setup?
$19.90 Hobby Lobby Yak 55 (see link below)
$29.90 Hobby Lobby 400XT Brussless Outrunner
$73.99 Tower Hobbies Hitec HFS-04MG Flight Pack S/J (single Con, RX 3 HS55 servos) Can I use the Futaba receiver below...only 4 grams heavier without the case....could use some light weight heat shrink to protect it?
$16.99 HS55 servos each
$39.95 Kokam 910mah 3 cell lipo
http://www.hobby-lobby.com/yak55.htm
http://www.hobby-lobby.com/brushless-skatty.htm
http://www2.towerhobbies.com/cgi-bin...?&I=LXFRT2&P=0
http://www2.towerhobbies.com/cgi-bin...?&I=LXJSH8&P=0
http://www2.towerhobbies.com/cgi-bin...?&I=LXTX42&P=V
What I have on hand
Futaba FP-R127DF 7 channel dual conversion RX 30/72.390 Weight without case 24 grams
Hitec 4-flash FM TX (could not find an exact manual...is the newer 4/5 Flash system X simular?)
Electrifly Polycharger for 1-3 cells...current charge 1000ma, 500ma and 250ma
Castle Creations Pixie-20p...Brand new in package but for brush motors...could use this below...
Prop size and prop saver/adaper...do I need this with a direct drive motor?
Also looking at this.... comes with brushed 370 bb motor Great Planes Yak 55 3D FlightFlex EP ARF This would take the wind better!
http://www2.towerhobbies.com/cgi-bin...?&I=LXKVY7&P=0
I could use my pixie-20p speed control...says good for up to speed 400 motors, 20amp cont, 30amp surge just .3 oz weight: http://www.castlecreations.com/produ...pixie-20p.html
Thank you to all for the suggestions....what do you think?
Ken
What I have on hand
Ken
IA
good set up need brushless cc10 is best prop size 10x6-10x4.7 i have 400xt motor
nice for the $$$ does nice job buy it, build it, fly it you'll have a blast
Sounds like you are not going with a bipe. If you are still interested in a bipe. I like my Fancy Foamy ultimate. AUW of 16oz, with a himax brushless outrunner and a 1320 battery it has all the performance you need. Slows down to a crawl and moves straight vertical with unlimited knifeedge. Also one of the best hovering planes I have.
Larry
Larry
