EPP 3D model Needed in UK
Hi folks, wonder if you can shed some light for me. I have a shockflyer with brushless set up and flies fine, plenty of power. But now I am looking for something that is stronger than the shock, as you know they can bend and break easily. SO i want something that is made of EPP foam, I have seen some around but dont know which ones are good. If you know of anything suitable which I can get in the UK or get shipped over here please let me know.
Similar size to the shock flyer, but just want something more robust.
Kind regards
Keith
Kind regards
Keith
Electric Foam Models - R3D-mini
Available at 3Dhobbyshop.com - http://www.3dhobbyshop.com/detail.aspx?ID=24
You can use the same equipment from your shockflyer and since the R3D-mini is made from EPP it is far more durable. It should be just what you are looking for.
Tim
Tim
