turmoil flat out
CA
hello, i just ordered a turmoil flat out and i would like to know what servo's would be best for it. I'm new to electric and would like some advice. thank you
I used HS-55s in my Cap. The "bays" that they mount in need a slight amount of triming for the 55s to fit. I would do that before everything gets glued together...it is a PITA to do it after the fact.
HTH
HTH
CA
thanks for the info..and giving the advice on the trimming and saving me frustration :P i was getting the 55's but wanted to see if those were the ideal ones to use... well i just hope to get the plane built and flying good now
hope it flys as good as it is talked about ...
later guys and thanks again
