Screamer mount for Shock Flyer?
BC, CANADA
I'm looking for a mount that will work with the Little Screamer for my Shocky Yak. A guy at a HS that gave me a Hobby Lobby URL- a detailed plan with dimentions for a plywood mount- but I lost the URL and I can't remember what the search term was that he used to find it.
I've since been unsuccessful searching the site using what I thought to be the obvious choices trying to find it. Can anyone help with this?
Thanks in advance, Ted
Hi Ted:
I made one from Plastic kitchen cutting board bought from Home depot. Cuts well with a bandsaw. Like cutting butter. Cut T shaped piece with the top of the T against the back of the motor. 5/16 by 1/2 and 2 in. long. the motor mount on mine has 4 lugs. so glued 2 pieces to the sides to accomedate the other two lugs screwed into the plastic with short sheet metal screws. Two 4-40 Allen bolts bolt it to the sides of the foam faced with 1/64 plywood. May be able to make a picture if I can get the camera to work. Hope this helps.
BC, CANADA
Thanks F2
It looks complicated, but I figure if I consider it a bit longer, it might get clearer. It would help if you could get a shot of it to post.....maybe?
The one I saw on the site that i really liked was made of plywood- really thin stuff which weighed next to nothing but was structurally strong...at least strong enough for this part. I'm really hoping that someone will see this and remember seeing it at the site I mentioned
T
T
I think this is the link you are looking for.
Hope it helps.
http://www.hobby-lobby.com/shockflyer-brushless.htm
Hope it helps.
