attaching batts to shocky
CO,
Hi, How do you all attach your batteries to your shock flyer. I am thinking of in-larging the opening in the fues and useing velcro. Should I add a strap, or do they wedge it there good enough? I will be usind 3 cell lipo 350-500 mah. Any Suggestions would be appreciated as this is my first Shocky build.
RE: attaching batts to shocky
In my shocky I use velcro to attach the battery in the centre of the fuse cutout on the bottom of the wing. I also put a small piece of foam on top of the battery to take up the space between it and the fuse. Works good. There is no way the battery would come out in flight.
