CG location on the typhoon
Where should the Cg be located on the typhoon? Mine seems tail heavy and flies horrible.(cant trim out the elevator it pitches up and down) I pick it up by the wing spar is molded into the wing and the tail drops. It doesnt matter if I check it with the included 9 cell nimh or a 2100 11.1 lipoly. thank you
