Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
 Shock Flyer VS. Flatouts >
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 01-08-2006 | 10:20 PM
Default Shock Flyer VS. Flatouts
So which one's are the best ????????? I have flown the shockie Edge and it's sweet. But I'm not sure to try a Flatout or stick with Shock Flyers
Old 01-08-2006 | 10:38 PM
bhole74's Avatar
Default RE: Shock Flyer VS. Flatouts
I would stick to the Shockys if I were you. Much better performers, especially if kept light.
Old 01-08-2006 | 11:20 PM
Here are my suggestions.
Either buy a shockie....or build the flatout like a shocky.
Get a reflection. Leave all the carbon and funky hinges out, and build it like a shockflyer. Taped hinges,box in the fuse with depron instead of using the carbon rod through the middle. Leave off all those plastic servo mounts, cross member braces etc. Take it from a 10oz airplane down to 6-7oz, and then it will be awesome.
Old 01-09-2006 | 11:32 AM
Stick with the shockys they are much better. You could build the flat outs like a shocky and they would be better. The only reason I wouldn't do that is the foam that they use to make the flat outs is heavier than what they use for the shockflyers in the first place.
