Parkzone Typhoon on its way!!!
CT
Just placed the order. I went with the plug and play.
This will be my setup
4 Hitec HS-81 servos
FP-T6NFK Futaba Conquest Radio
Hitec Electron 6 Receiver
Thunder Power 3 Cell 2100 mAh Lithium Poly
This setup should be good, let me know what you guys think. I can't wait to try it out!!!
That sounds like a good setup. I'm running mine bone stock & it's still a fun plane. I'd recommend puting some packing tape around the tailwheel assembly when you get it. The foam it attaches to breaks off with even easy landings.
Good luck
Good luck
