tensor 4d any advice?
AZ
RE: tensor 4d any advice?
I built mine as the instructions said to and it flys really well. Just keep the tensor light when building it, also keep it straight, build it on a flat surface. Use foam safe CA glue, it tends to be the strongest and lightest, also it is easy to work with.
When flying the tensor use rudder to turn the plane. It will not turn with the ailerons. Also flys knife edge all by its self with out giving any input of rudder.
Pete
Pete
MO
I glued a peice of 3mm cf on the top and bottom of the fuse from the wing to the tail for added strength. Also changed the linkage connecting the ailerons.[link]http://www.rcuniverse.com/forum/m_2438988/anchors_4245201/mpage_20/key_/anchor/tm.htm#4245201[/link]
My Feedback: (12)
WA
Actually, it will turn by ailerons and elevators, but i found it needs (or looked) 60 deg of bank to do so. im so familiar with using rudder that its no big deal after a minute or 2 of flying it. it does like calm or no wind to get the best out of it. building it straight is a must, depending on what you intend for it.
ON, CANADA
ORIGINAL: fly pete
Pete
Pete
Peter
