3d foamy Katana S Questions
MI
I'm building this plane, and I'm pretty much done, but I can't figure out where the cg is, does anyone here know? I was also wondering how well a 730 mah lipo will power this plane with an e-flite 370 motor, i'm not sure if I need to upgrade or not, thanks.
GA
RE: 3d foamy Katana S Questions
I have mine just a bit rear of the carbon rod on the wing... I ran a Axi 2208/34 and it was insane.. 1320 3s batts.. You should be fine just short flights..
LATER
LATER
