New - Katana S30e by Sebart - Looks Awesome
My Feedback: (18)
GA
RE: New - Katana S30e by Sebart - Looks Awesome
Luigi posted in the other forum that they are HERE!! Mine should be here soon and I'll post some pictures. Can't wait!!
My Feedback: (23)
Bill,
I saw on an RC-groups thread about this plane that the Hacker A30-10XL has 600 watts. But I went to Hacker's website and they say it only has 450 watts.
http://www.hackerbrushless.com/motors_a30.shtml
My Feedback: (18)
GA
ORIGINAL: ben beyer
Bill,
Bill,
http://www.espritmodel.com/index.asp...OD&ProdID=4989
I would have to say that he must be pretty close considering people use it in the Banchee, and E3D, etc.
#31
My Feedback: (23)
Yeah, I imagine there are differences in what a motor can do and what the company that makes it can do. A similar example was the JR 8611 and Hitec 5955 servos. Independent testers found they were capable of more than what JR and Hitec said they could do. I wonder if anyone has tested the Torque motor to see if it's about 518 watts.
I did some research and I think the Thunder Power Pro-lite 2100 3S1P may be the way to go. One guy I've talking to that has one over in Germany said he liked using the Evo 1800 maH pack for 3D because he could hover at 1/2 throttle, but he only got 5:30 flight time. Now, that pack weighs 145g and the TP weighs 142g plus you have 300 more maH and that's only 70 maH less than the recommended Evo 2170 3S1P pack, but weighs 28 grams less.
What are your thoughts?
#32
My Feedback: (18)
GA
Ben,
Normally, I'm all about lighter is better, however I've found in planes these size two things can happen if you try to get to light. One getting the CG spot on, can be a bear, and you may end up to aft to be able to anything but hover well. The second thing is that they become like kites in any sort of wind. With a little more weight they just seem to drive through the wind better than if they are just to light. I like light, don't get me wrong, but you can get too light IMO.
Until I get my hands on this plane and really look at it though and see, I can't say. I bought one of the new TP Extrem 2070 packs to try and I'm going to try one of Luigi's Evo packs, so we'll see how it comes out.
I don't mind 5 or 6 minute flight times, so long as I've got a pack or three.
#33
My Feedback: (23)
I agree with you entirely. I was just thinking of perspective performance. I have a WH CAP and some people probably consider it to be a pig at this altitude because it's a little over 17 lbs., but it can handle the wind and the 3W 56 I have in it can still pull it out of hover. Probably also comes down to user preference in my opinion, but I would still like to try some of those Evo packs to.
#35
My Feedback: (18)
GA
ORIGINAL: ben beyer
#36
ORIGINAL: ben beyer
#37
My Feedback: (18)
GA
ORIGINAL: CTB
I saw one of these beautiful planes being put through its paces today. Absolutely awesome. Setup was the recommended A30-14L plus a TP Prolite 3S 2100.
ORIGINAL: ben beyer
#38
ORIGINAL: Bill Killillay
Any chance you know what his AUW is, and what other gear he might be using, servo's, RX, etc?
TP Pro-lite 2100 3S pack (145 grams).
Spektrum DX7 AR7000 Rx
Hacker 30 - 14L
Hitec HS 65 servos (I think).
ASP 14x7 prop.
#39
My Feedback: (18)
GA
ORIGINAL: CTB
AUW No. However I know what he had in it.
Hacker 30 - 14L
ASP 14x7 prop.
Hacker 30 - 14L
ASP 14x7 prop.
#40
Hello All
I,ve Just flown my Sebart Katana 30 E for the first time, and its great.
Tornado 2100 3S pack
Hitec HFS-05MS Micro 35MHz Receiver
Hacker 30 - 14L
Hitec HS 65 servos
ASP 14x7 prop.
Tatal Weight 2lbs 15oz. There's someone on RC Group using a 3 cell 3200 lipo, and still flies great.
Kevvy.
Hacker 30 - 14L
Hitec HS 65 servos
ASP 14x7 prop.
Kevvy.
#41
My Feedback: (18)
GA
ORIGINAL: Kevvy
Hello All
Hacker 30 - 14L
Hitec HS 65 servos
ASP 14x7 prop.
Kevvy.
Hello All
Hacker 30 - 14L
Hitec HS 65 servos
ASP 14x7 prop.
Kevvy.
Thanks for the report!!
BK
#42
Dear Friends,
For me the best and light set up is:
Hacker A30/14L
HAcker X40-Pro ESC
JR 285 servos very fast and powerfull
Flight Power 2170mah 3S 25C Impressive for high discarghe
with this set up the katana S30e is very light 1270grams..... I don't know in lbs, and you can fly about 7/8 minutes of awesome 3D, ciao Alfo
Wishing you a Merry X-mas and a happy 2007!!!
Hacker A30/14L
HAcker X40-Pro ESC
#43
My Feedback: (18)
GA
ORIGINAL: fonzie72
Dear Friends,
Hacker A30/14L
HAcker X40-Pro ESC
Dear Friends,
Hacker A30/14L
HAcker X40-Pro ESC
That's:
44.798 oz.
OR
2.800 lbs.
Pretty darn impressive if you ask me!! But your not, you already know it. Luigi said that mine should be shipping soon... can't wait, can't wait!!
#44
I got the oportunity to put one of these together for a friend. Very good quality aircraft. He aslo let me fly it all I can say is WOW!! I ordered mine today and am pulling the gear from my EF yak to put in it..
Torque motor 2814 - 820 Fits perfect and has the power 500 watts
Air Boss 45
HS 65 servos all the way around
Evo 2170 and TP extreme 2070 3 cell
AR6100 rx ( as soon as they become available) till then what ever 6 ch rx I pick up from my box of electronic stuff.
Air Boss 45
#45
CA
I just finished putting mine together day before yesterday. Here's the equipment:
Axi 2820/10
JETI +40 ESC
Evo 2150 3S
Hitec HS 65's all around
The weight came in at 46.9 oz., a little heavy compared to some of the other setups (might be the motor/ESC combo?).
I'm still debating with myself on the prop. Currently I have Graupner CAM 11x6 on it - it draws about 37 A with that at full bore.
Might switch to a APC 11x7E tomorrow, or whenever the first halfway decent flying day comes up.
Ed
Axi 2820/10
JETI +40 ESC
Evo 2150 3S
Ed
#46
My Feedback: (18)
GA
Both of my setups have come in at or around your weight and the plane handles the weight just fine. I'm not sure about those prop sizes though as the smallest that I've flown with is a 13x6.5. Let us know what you settle on.
BK
BK
ORIGINAL: eschummer
Axi 2820/10
JETI +40 ESC
Evo 2150 3S
Ed
Axi 2820/10
JETI +40 ESC
Evo 2150 3S
Ed
#47
CA
Hmmm ...
This is a 475W (max) motor. Everywhere in the specs it calls for props in the size of 11x5.5 to 12x6. Max current is said to be 42A. I'm afarid I might exceed that with a bigger prop...Any experience with this motor? I've been pretty happy with the smaller AXI's (2808) on smaller models (Mini-Katana, Edge 540, etc.).
Thanks, Ed
PS: I'm pretty new to all this elctric stuff...(my other plane is a 102" Katana with a 3W 106)
Thanks, Ed
#48
My Feedback: (18)
GA
Ed,
While it's probably ok to go up to a 12 or even 13 due to the fact that the props unload in the air and current draw drops off a lot it's your call. I'm running a Hacker A30-12L and ran a 10XL before that. Both are rated for higher props. I have no personal experience with that Axi, but I've flown enough of them in my time and they will treat you right. I would not do a lot of bench testing with a larger prop as that will heat things up a lot. Best thing would be a short test to see where it's at, and do a series of short test flights to see what the motor, battery and esc temps come down at if you decide to go up to a larger prop. You may find that the 11 or 12 is fine. I would recommend going up in small steps though for sure.
BK
BK
ORIGINAL: eschummer
Hmmm ...
Thanks, Ed
Hmmm ...
Thanks, Ed
#49
The FUNTANA 140S is really sweet too!!!!!
Wish mine was the Seba Green and red!!!
http://media.putfile.com/FUTABA-14MZ...0-FUNTANA-140S
#50
My Feedback: (51)
This is the same new motor and ESC used in the QQ 49"... I have them and will soon be testing on 3s and 4s packs... the 3s can spin a 14x7 prop and the 4s needs to drop down to a 12x6... The planes are similar in weight so power to weight performance should be nearly identical...
