hacker X-20 ESC and futaba receiver compatible?
My Feedback: (55)
CA
RE: hacker X-20 ESC and futaba receiver compatible?
It Should Work Fine. I have never run into a situation where an ESC didn't work with a receiver. I believe there all compatible. [sm=bananahead.gif]
VA
Agreed, ESC's are pretty much universal. It should work just fine. Just make sure you plug the connector into the Rx so that wire colors match from the ESC ared plugged in the same way as your servos and you'll be fine. I've plugged the ESC in backwards though on my JR Rx's and the ESC provided power, but the throttle didn't work. No harm done though.
