Extreme Flight Yak 54 E
'Bout to get an EF Yak 54. Was also gonna get a Spektrum DX6, would this be a good fit? Will the servos that come with the DX6 be enough for the Yak? Also what about range? It's imposible to get a range in feet for those Spektrums. Cheers -Zach
IN
ORIGINAL: 01SCSS
Yes the DX6 will work with the EF YAK 54E, I would use the 65's that are recommended. I am pretty sure that the servos that come with the DX6 are s75 and should work also.
Personally I do not understand why people ask how far a radio will work, if you can't see it you can't fly it, if you can barely see it your in trouble but if you keep it at comfortably safe distance with a good view of the aircraft you will be fine.
Steve
