Mini Inspire Tuning
I am getting pretty good at tuning 3D planes, but this one has me a little stumped. I like to get a neutral inverted flight. I keep moving the battery back and have even added 1/2 oz lead to the tail. The CG is now 1/2" back from the Carbon Fiber spar (further back than they recommend). Still need to give down when inverted.
I am thinking perhaps I should play with the thrust line a little. It looks like it has up thrust. Has anyone had this same problem with the Mini Inspire, what CG did you try and did you mess with the thrust?
(I have had two Fliton Prodigies (its little brother) They trim perfectly to neutral inverted flight, so I don't get the problem with the Mini Inspire)
Thanks in advance,
Larry
Thanks in advance,
Larry
Just thought I would terminate this thread. The answer is to build a new battery mount and slide everything into the rear. Mine currently balances at 4 3/4" inches back from the leading edge, and it is close to neutral inverted. This is much farther back than I have read about on any thread or in the manual, hence the confusion.
It flies well and I think it is a keeper. I do wish they offered a model with solid colors to provide more contrast on the wings. I think I will add some checker boards.
Larry
Larry
