Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
 Battery For Hacker A20-20L on Fliton Mini? >
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 06-15-2007 | 11:07 AM
Default Battery For Hacker A20-20L on Fliton Mini?
Hi all,
What size (mah) battery is best for a Hacker A20-20L on a Fliton Mini Extra? I have a TP 1320, but I'm not sure how many minutes of flying time I'm going to get?
thanks for your answers,
Alex
Old 06-15-2007 | 04:46 PM
Fliprob17's Avatar
Default RE: Battery For Hacker A20-20L on Fliton Mini?
That should be fine. If you go up to a 2100mah the plane is going to get a little heavy and throw your CG off. I have a similar power/amp setup. You should get about 8-9 minutes with that setup.
Old 06-16-2007 | 08:04 PM
WhtBronco's Avatar
Since I am always trying to keep my park flyers as light as possible I use only Thunder Power 3S 910mah li-po's with my Hacker A20-20L. I get 8 minutes of flying hard 3D with it and it's an ounce lighter than the 1320's.
