balsa 3d
WA
I am building a fliton rogue 3d bipe, I haven't finished it yet but it is a very cool looking plane. and very well built.(www.fliton.com)
MI
i was looking at the parkflyers geebee rtf 3d plane it looks coll and has some good reviews does anyone have exspierience with this plane?
thanks
thanks
TX
ORIGINAL: sokrdz
thanks
thanks
Kevin
MI
well i sort of got desperate. but i would prefer balsa.
i found these two do you think they are any good?
http://www.flying-kit.com/index_epro...roducts_id=374
http://www.hobby-lobby.com/reflex.htm
I have several ARF Balsa built up models none of which I find exciting enough to recomend. Stay away from the no name Ebay specials. They aren't what you are looking for either. I bought several so far from different vendors. If you haven't flown a sub 6 oz 3d Foamie then try that and if you find a balsa model that flys as well then please let me know what it is I want one too.
TX
Airfoilz would take my vote. I don't have one of there plane, but have read alot of threads and no bad rep sooooo I would say that their good, and don't worry they are balsa..... on the inside
Kevin
...Kevin
AL
ORIGINAL: 3D-Flyer Kevin
Kevin
...Kevin
MN
The 3dhobbyshop.com planes are supposed to be phenomenal. They have a pretty good video demo on their site as well. I would backup the vote for an Airfoilz, if you're not dead set on balsa.
Just my $.02
- Chaz
Just my $.02
- Chaz
NE
Thanks for all the support WhtBronco.
The Skeeter 30 is also now available as an ARF:
[link=http://kalteisen.com/skeeter_30_arf.html]http://kalteisen.com/skeeter_30_arf.html[/link]
I'd like to know about that plane from www.flying-kit.com. I ripped off the landing gear from my plane and am looking for a cheap purchasable one. I built the one in the picture from a foam plane template. Yes, it did have an motor when I flew it. I can repair my plane but one day I'll need another one. The Flying Kit plane is from Hong Kong and I was wondering if it will actually make it here in one piece.
I think that's the model you need.....Oxalis parkflyer....look at this complete video....3d and pattern easly
byeee
http://www.youtube.com/watch?v=E34pcJcsiHM
byeee
VA
The E-flight Cap 262BP is a worth considering. With the recommended 450 motor and ESC, four Futaba 3114 servoes and a 900 mil Inpulse three cell pack, mine weighs 15.3 ounces. It flys slow flight as good a most foamies, but because of it relatively thick airfoil it flys fast flight or windy flight like a real airplane, with none of the jumpiness of a foamy. It assembled in almost exactly the four hours stated on the box. It is a joy to hover, hovering almost as well as my Reflecton Foamy. Makes air catchs real easy. I've banged it into the ground several times from a hover on windy days and so far it has sustained no real damage. It does great walls, elevators, waterfalls, and harriers, fair blenders and has very little coupling in knife edge flight. I highly recommend it for a light weight balsa 3D plane.
