Katana Mini Power Question
IN
I have a Katana Mini that I just built and need a recommendation for that I will be able to use a Heli-Max 25A speed control and a 3 Cell 2100mah 16C rated battery pack, I would like to use a stick mount gear box.
Thanx,
Matt
Thanx,
Matt
on mine i used a hacker a30-28s outrunner, using castle 25 esc, and 1800-2100 packs, power was awesome!, for gearbox setup i think people are using teh himax 2025 and cobri gearbox.
ORIGINAL: whop12
Thank you Daniel,
Do you happen to know if the Himax 2025 is the 4200 or the 5300?
Matt
Thank you Daniel,
Matt
http://www.rcgroups.com/forums/showt...52#post7733710
