P/A E.Shock Help
Ok so i finished me eshock with all the recommend gear from P.A and what an great little plane to put together im not the best builder and it only took me 4 days and it was ready to fly. So on the 5th morning i was out out the feild and first flight no dramas flew really nice. im no 3d pilot yet but dam this thing make moves easy. i landed without a problem changed battery and went to go again but all that will happen is the motor just giggles but wont turn over at any throttle setting but the servos still have power. Tried again in about half hour as i had other planes there. same thing no go.then tried in like 3 hours time and away it went. So this morning i get up charged the lipo plugged it in and went for a flight no problem landed and the same thing happened again. Why is this and What can i do to stop it i like my little plane and want to be able to have lots of flights Help
This is my setup all pa gear http://precisionaerobatics.com/produ...px?prodID=1101
It sounds like you are not properly arming your ESC when you change the batttery. Many of my planes need me to push to full throttle for a second, then back to no throttle for a second before the motor will do a thing. I see your ESC has a "Power Arming Protection" scheme, so you need to go look at your directions for the specifics.
As far as i can tell its not an esc that needs to do it. My dad now has a couple of elertics and 1 of his is like that yes. but the other is not like mine i think. Foward stick is for progaming mode. After the flight i unpluged and pluged it straight back in and no go. But after i got home from work that day pluged it in and it started without a prob. Please help as i want more air time than just 1 flight every few hours
