3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
help!?!?!?!?!?!?!?
Old 07-05-2008 | 07:46 PM
Default help!?!?!?!?!?!?!?
HI i just got my sobre put together with all the servos s75, speedcontrol elfight 10amp, elfight 370, eflight 2 cell 800, and dx6i. When i first turned it on i tried to see if the motor had power it did so i went wide open and it pulled really hard them slowed and stopped after about a second, i had this same problem with the fiego in my buggy and it was the endbell spinning on the can does any body know what i need to do to fix this.
Old 07-05-2008 | 07:51 PM
Xpress's Avatar
Default RE: help!?!?!?!?!?!?!?
Sounds like your lipo is not charged, and you speed controll cut off the motor before you drained your battery too much. Try charging it
Old 07-05-2008 | 07:53 PM
ii just realized i had the lipo cut off at 9 v when the lipo 2 cell at full charge was at 8.71v wow i feel really dumb for not catching that
Old 07-09-2008 | 02:00 AM
You probably have the ESC set for 3 cells that's the default setting make sure you have it on two cell. Plus if you ever want to enjoy your plane at his full 3D capability you will need a 3 cell lipo.
Fernando
