Go Back  RCU Forums > Electric Aircraft Universe > 3D Electric Flying!
 Multiplex Gemini Bi Plane >
3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Old 12-03-2009 | 01:13 PM
dendar's Avatar
Default Multiplex Gemini Bi Plane
Hello,
I just purchased a Gemini Bi-Plane by Multiplex. The question is when I take off and get a few feet off the ground the airplane tends to roll to the left. I have to apply a little right aileron. Once airborn it flies straight. I have about 3 degrees of right thrust set up just like to book calls out for. Can someone explain why this happens?
Thanks for the help
Dendar
Old 12-03-2009 | 07:24 PM
Cleared2Engage's Avatar
Default RE: Multiplex Gemini Bi Plane
If it was rolling left I would say it is torque. Might want to re-check your thrust angle on the motor mount.
Old 12-04-2009 | 11:21 AM
dendar's Avatar
Should I increase the right thrust to 4 degrees. That is the max they call out for in their manual.
Old 12-04-2009 | 09:36 PM
If that's the max then I would say give it a shot. It wouldn't hurt to try it out for one flight and see if that makes a difference.
