3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
slowflyer prop for 3d?
Old 01-18-2010 | 09:25 AM
Default slowflyer prop for 3d?
Are the APC slowflyer props good for 3d? I heard there is a weight limit of about 24 oz. for any sf prop. I need a 12" prop with less than 4" of pitch and can't find any normal E props like that. My plane weighs 26 oz.
Old 01-18-2010 | 11:34 AM
tIANci's Avatar
Default RE: slowflyer prop for 3d?
Hitman ... used the props before, they are okay ...
Old 01-18-2010 | 06:15 PM
My Feedback: (10)
I never heard that about weight limit for sf props but it makes a lot of sense - you don't want to power an sf prop so much that a blade comes off!
I have a profile Katana with 36" w/s, weighing in at 27 ounces with 2x1000mah or 2x1300mah 3S packs. I used to use sf props for the same reason as you, but now I have started using GWS HD or DD props - in fact right now a 10x6DD, with good results. The motor is a Chinese outrunner - RC1050 running at 1050kv and about 275 watts maximum. I get about 12 minutes of thrashing around. I used to use less energy (mah/minute) using a 10x4.7 or the 3.8 pitch GWS props, but I took some flak from club members who didn't want their eyes impaled by rogue sf prop blades coming off. I told them to get a sense of humour and wear protective eyeglasses, but they just didn't get it!
Old 01-18-2010 | 06:43 PM
I wasn't planning on more than maybe 250W. my plane is 36" span and 26 oz. 950 kv motor with 3s 1500mah pack. 8 minute flights. I've tried 11x5.5,12x6, 12x8. None are very good with this setup for 3d. That 11x5.5 could be ok if I go up to a 4s maybe. What do you think?
