RCU Forums
-   3D Electric Flying! (https://www.rcuniverse.com/forum/3d-electric-flying-237/)
-   -   HOVERING! (https://www.rcuniverse.com/forum/3d-electric-flying-237/1507475-hovering.html)
koi 02-08-2004 01:06 AM
HOVERING!
Is the formula for power required to hover 1.5 times the weight of the aircraft? If so then a 14oz. aircraft would need about 21oz of thrust. This isn't working for me so there must be another number to work with.
To add to this confusion for me the 3D that is mentioned here uses a battery that is Li-Poly 3Sp 1200 mAh with a 300 EPS motor, that should fry the motor or am I missing something. This is like swimming up stream what a challange.
[:o]
Kyle2Baseball 02-08-2004 01:48 PM
RE: HOVERING!
That should be pleanty You could hover with a 1:1.5 ratio It just wont have great climb out.
flip3d 02-08-2004 09:18 PM
RE: HOVERING!
no it will be fine.
just u will onley get maby 20 min of motor life out of it.
id go brushless.
himaxx 2015 4100 phenix 25 speed controler. gws gear box with the d drive
gws 12 6 prop
i have that set up and love it.
flip
crashingagain 02-08-2004 10:26 PM
RE: HOVERING!
It will hover, can you?I can semi hover on my 3dx but the elevator is flimsy and the halves tend to flop around alot. Try moving your c.g. back a bit
koi 02-10-2004 06:54 PM
RE: HOVERING!
My C.G. is right behind the spar of the wing should I go further back?[sm=confused.gif]
Hey flip how much did that brushless set-up cost you?
