3D Foamy
Ok guys,, i'm think'n of ordering a foamy from 3D Foamy, and was wondering which one you guys recomment? Which ones do you have, and fly?
Let me know your thoughts! Thanks! |
RE: 3D Foamy
i had the katana. i now have the cap. personaly all foamys fly the same to me depending on wing area. the lighter the wing loading the calmer the conditions have to be to fly. you will love wich ever one you get.
RE: 3D Foamy
www.fancyfoam.com. Great kits, support and quality. You can go from an airframe to a complete kit.
Hank |
RE: 3D Foamy
1 Attachment(s)
I'd suggest the Cap 232. So easy to hover!! The Katana was kinda hard to hover and IMHO it didn't fly as good as the cap.
CAP 232!! TTYL, Andrew T. |
RE: 3D Foamy
your katans cg was to far forwards i bet
RE: 3D Foamy
Glad to hear it! Kuz,, i just ordered the Cap! I can't wait!!:D
RE: 3D Foamy
3D Foamy is a great place to do business with and their designs are lights out both in quality and flyability. Great choice.
RE: 3D Foamy
The Katana takes a bit more dedication to hover... mostly because the ailerons end further outboard. (Prop wash is less over them)
But I'm one for looks and so I kept everything scale. |
RE: 3D Foamy
When I started, I told Tim from Foamy Factory that I wouldn't be doing any of the planes that he has... So thats why I don't have the Yak 54 or the Ultimate.
I do plan on a Yak 55 though. It sucked the big one in the full scale world, but I think it has the correct proportions for Precision 3D... Right now I am finishing work on the Advantage Bipe (SWEET!) and then I've got a few others (Super Chipmunk, CAP 10, and the F-15/F22) |
RE: 3D Foamy
Levi,,
did you get caught up on your orders yet? I just ordered the Cap tonight and am sooooo excited to get it! As soon as i get it and get it up in the air,, i'll take some vid! |
RE: 3D Foamy
hey levi i think u should do a yak 54.
it would compleat the 3d aerobatic line of aeroplanes. flip |
RE: 3D Foamy
A yak 55?? Now that would be kewl!!! I had a Yak 55 foamie made my another person and i thought it was the easiest plane i've ever hovered.
TTYL, Andrew T. |
RE: 3D Foamy
Any sneek pics of the Advantage? What is it going to take to fly it?
RE: 3D Foamy
craigman -
I am also looking at the cap, and i was wondering what motor, battery, prop, etc. you were going to put in it. I don't know much about electrics so I'm kinda a newb on this one. I'm not quite sure what would be the best setup. THx, :D |
RE: 3D Foamy
I've got the Eflight 370 brushless, 10 amp castle speed controller, Kokam 3 cell, and Cirrus micro servos, and GWS reciever for it.
Right now i have everything going into a Eflight Ultimate. So when i tear that up, i'll put it all into the Cap. I can't wait! |
RE: 3D Foamy
Once again, i don't mean to sound noobish, but is that a good setup for virtually all 3d? I have been checking out some sites about them and I'm not sure what engine will do what and so forth. I just want to make sure if i pay all this money i get it right the first time:D I was looking at www.3dfoamy.com and their specs, but was still unsure. I believ that is where I'm gonna order the cap from, but like i said, i am unsure about everything else. Thxz again. :)
Oh, i'll post what im gonna put in her up in the forums on last time to make sure all is ok. :) |
RE: 3D Foamy
The set up I've been using for the last year which works great and it reasonably priced is: Himax 2015-4100 motor, GWS EPS gearbox with "D" gearing, Castle Creations Phoenix 25 amp ESC and a 3s 1200 mAh lipoly pack of good quality such as an E-tech or Thunderpower.
This set up performs perfect in a foamy of the size that 3D Foamy sells. Plenty of power and it won't break the bank. Sure you will net a little more power with a Razor or Hacker but you'll pay twice the cost of a Himax to get it. I hope this helps but one thing's for sure, you can't do any better than choosing 3D Foamy for a flat plane. |
RE: 3D Foamy
Craigman... almost all cought up! I'm getting the F-18 park jets done right now.... I should be to your kit on Tuesday.
T1nk>>> TAshley got it right on that last post... thats a great setup. Only thing I would add is that the AXI 2212-34 and a pheonix 10 ESC is a good choice too... Basically if you look at that motor chart on the "About Motor" page.... anything you pick off that list will be great. |
RE: 3D Foamy
Don't forget to check out insanefoamies.com.
You can buy everything you need to get started in 1 package. |
RE: 3D Foamy
Crash, whice 3D Foamy design have you built. Just asking, I've built five of them and they went together great for me.
RE: 3D Foamy
RE: 3D Foamy
Sounds like you should be buying ready to fly planes if you can't build a 3DFoamy.com plane...
Are you in any way associated with the company you endorsed or have something against 3DFoamy... Just curious |
RE: 3D Foamy
RE: 3D Foamy
I respect your answer and your integrity, I was unsure as their tends to be many trolls on these boards.
I used Robart hinges on my control surfaces and so far so good. The spar trough was really not that difficult to make, just score it with a new razor blade and scrape it out with the carbon fiber spar. Just take your time. Also be careful not to go too deep. I believe it is better to have some of the spar 'sticking out' of the bottom of the wing than to go through the top. I agree there are a few tricky parts on the assembly, but that is to be expected of any kit out there. I have built everything from static plastic models to R/C submarines and have learned to 'enjoy' the tricks. -Adam |
RE: 3D Foamy
Haven't seen the robart micro hinges yet. The match pack worked great. I had considered using my soldering iron to burn a small groove into the wing for the spar. I should have done that. I was just determined to get that spar down low enough so it sat flush with the bottom of the wing. Again, that's just me being anal.
Happy flying. |
| All times are GMT -8. The time now is 04:32 PM. |
