RCU Forums
-   3D Electric Flying! (https://www.rcuniverse.com/forum/3d-electric-flying-237/)
-   -   VPP Upgrading (https://www.rcuniverse.com/forum/3d-electric-flying-237/2883751-vpp-upgrading.html)
NZ Private 04-16-2005 11:06 PM
VPP Upgrading
Hey, I was thinking of getting a VPP set from Hobby-lobby and get the axi motor with it, then get a Pheonix 10 brushless esc and have a 2 cell 1320maH li po along with a jr XF631 (6 channel) an Jr R610M reciever all in a reach Whirlwind ( http://www.reach-model.com/products_0.htm ) do you think this would work ok (i would also use jr micro servos)
Thoughts???
Maidin
NZ Private 04-16-2005 11:15 PM
RE: VPP Upgrading
does anyone know if this would work ok?? or else wot you would recomend
locoworks 04-17-2005 04:16 AM
RE: VPP Upgrading
depends what model?. checkout my post on IKARUS VPP, much lighter than a 2208...
flyboone 04-17-2005 09:25 AM
RE: VPP Upgrading
You will need a 3 cell battery for out VPP system. If the plane weighs 10 ounces or less you'll have a blast.
Jason
Hobby Lobby Asst Sales Mgr
NZ Private 04-17-2005 01:52 PM
RE: VPP Upgrading
1 Attachment(s)
I'm using a reach Whirlwind picture below it can be found at http://www.reach-model.com/products_0.htm.
Also how much performance could you get from a 2 cell 1350mah lipo??
colesifer3d314 04-17-2005 03:43 PM
RE: VPP Upgrading
u will need a Phoenix 25 ESC...a 10 is not enough for that motor...i have the same set up on a Lee Ulinger Foamtana with a 3 cell 1050 duralite pack...insane power for indore and inverted hovers r very stable
flyboone 04-17-2005 04:30 PM
RE: VPP Upgrading
A 10 Amp controller will be fine for the 2208/34 motor. We run the Jeti 8 Amp controllers with them. You really will need the 3 cell battery though.
Jason
NZ Private 04-17-2005 08:20 PM
RE: VPP Upgrading
ORIGINAL: ColeThornton
an axi would work just fine (a 2208/34 its built for that, kinda)
