Sebart SU29-30
1 Attachment(s)
Here is my new toy, Sebart's SU29-30. She is a lovely plane and the build was pretty straight forward. If you are using HS65s you will need to enlarge the servo wells a bit.
My set up is as follows: Motor: DualSky 3548-5 Speed Control: Turnigy 60A Battery: Flight Power 25C 4S 2500 mAh Prop: APC13x6.5e Servos: HS65 At the moment she is pulling 59A @ 825W. Hope to be able to maiden her soon. :) |
| All times are GMT -8. The time now is 04:01 PM. |
