Need Help choosing Gasser 40-45cc
I bought a like new Extreme Flight Yak-54 74" with an OS 1.60. I want to ditch the nittro and go gas. The manufacutre says I could put up to a 45cc gas engine. Anyone know a good light weight power house enough to support a 12-14lb plane.
My Feedback: (88)
AR
RE: Need Help choosing Gasser 40-45cc
Look through the EF Yak 74 thread. I think a couple of guys are running the CRRC 40 cc in it. Its a little lighter than the Brilelli 46 and will turn a 20x8 prop around 7000 rpm. i think there is even somebody running a DLE 30 in one.
My Feedback: (13)
OH
i have a couple of flying buddies that have the same plane.one has a RCGF 45 and the other had a Brilelli 45 and both said that it is to much weight up front.the DLE30 would be a better choice if you need a gasser.they both said that the plane flew heavy.
OS 1.60 Makes 3.7 hp Engine- 930g (32.8oz) Muffler- 275g (9.7oz) = 42.5oz swings 18x10-12 $320
These include CDI an Muffler:
Zenoah ZG45 weighs 79oz with muffler swings 18x8 - 21x8
DLE 30cc 38.45 oz or 2.4lbs 18x10,19x8,20x8 3.7 hp $319
MT-35 35cc 38.8oz 18x6 - 20x8 $279
RCGF 32CC Gas Engine 38.8 oz 3.9 hp 18x8 19x8 20x8 $316
RCGF 45CC Gas Engine (Rear Crank Case) 54.7oz 4.3hp 20x10 $260
My Feedback: (57)
IN
That airframe is heavy before you add an engine. I'd leave the 160 on it.
You won't come close to that power/weight ratio with gas, especially if you have any hope of 3D with it.
