 3D prop for magnum 52 4-stroke >
Old 12-14-2010 | 06:19 PM
My Feedback: (40)
Default 3D prop for magnum 52 4-stroke
whats a good prop to put on a magnum 52 4-stroke...its on H9 tribute 36
Old 12-15-2010 | 12:08 AM
Default RE: 3D prop for magnum 52 4-stroke
I am not much familiar with Magnum, but going by size analogy, I will give it a try. Say the manual recommends 12x6 as the largest prop size, then a good starting point for a 3D prop would be on size higher and one or two pitch lower e.g. 13x4. I would give 12x5 a try first. Note, run this prop only after you have completed the run-in with the recommended prop as per manual.
Ameyam
