Fuel tank set up
I'm thinking of changing the clunk line in my Gas tank to Hays neoprene and I've seen some guys use a small section of brass tube in the middle to stop the clunk getting hooked up at the front of the tank.
Good idea or not??
Falcon
Good idea or not??
Falcon
My Feedback: (44)
ME
I wouldn't recommend neoprene, it will break down with the new blended gas and clog your carb at least here in the states. Not sure if you guys run any E-10 blends over there or have any other additives. I just did 3 water bottle gas tanks and used viton tubing and it works great. I did use a section of brass with 2 short sections of viton in the tank.
http://www.thunderboltrc.com/tutoria...rial_five.html
place to buy the line.
http://www.redaerorc.com/
maineflyer
As far as I can tell here in the UK they can add 5% ethanol, would that be a problem?
DMcQuinn
My tank is only 16 ounce, is it worth doing on a small tank like that?
rcflip
No offence, are you sure it was Hayes, Dubro make a neoprene tube which has a seam in it that can split, the Hayes tube is seamless.
Falcon
DMcQuinn
rcflip
Falcon
My Feedback: (44)
ME
Not sure but I wouldn't chance it as it can gum up the carb. We have 10% ethanol and from what is reported the neoprene breaks down and problems start. The viton is made for gas and maintains it's flexibility.
DMcQuinn
Thanks for that, saves me a little work.
maineflyer
Thank you, I think i've found a source for the Viton tube here in the U.K. but not sure if they sell it in small quantities?
As far as I can see the inside diameter is available in either 2mm or 3mm - the 3mm being just under 1/8, would that be OK ?
Thanks Guys
Falcon
maineflyer
Thanks Guys
Falcon
No it was definitely Hayes, I remember buying it and still have some in the packet, Hayes is good stuff but I will not use it in a gasser, it is good in Nitro but I have found batches to be bad, sometimes you just get a bad batch, and it will not last, it just disintegrates.
