saito 100
NC
will the 100 saito pull this plane out of a hover with athority becouse i have a 91 and it will just barly get out of a hover, ive seen 4 of these fly with a 91 saito and they all lack power pulling out of a hover. they all weigh around 7lbs
Excuse me, but what are you asking?
What plane are we reffering to here?
The Saito FA-100 should have no difficulty pulling any 3D bird in the 6.5-7.5 pound range out of a hover.
1) On a 6.75 pound Ultra Stick 60 it rockets to unlimited virtical.
2) On a 7.5 pound U-Can-Do 3D it will do just about the same.
My Feedback: (19)
JS
Can you enlighten me on the cline regulator. Does it help an inverted saito idle better? I have one inverted and it runs great until I take off the glow igniter then runs pretty rough. If I lean out the low end any more it just quits when transitioning into full throttle. Any help would be appreciated.
JLS
JLS
JLS,
Yep ... purrs like a kitten at idle and smooth mid range. It's not a cheap little piece, but it works so it's worth it in my book. Bottom end will need to be leaned out quite a bit after installation. Once you do that you're all set.
JS
JS
