dp edge 540
Make sure you have it trimmed and the incidence is right on the stab and engine thust line. An aft CG will also cause the plane to pitch to the belly on knife edge. Also, being overweight will increase this phenominon. Got like a Brison 3.2 in it?
I'm not an aeronautical engineer so I can't explain it , but there is a post in the 200 word range regarding this issue if you do a search on knife edge pitch coupling.
I looked it up for
you..http://www.rcuniverse.com/showthread...ght=knife+edge]
I looked it up for
CA
I also have a DP Edge. Running a DA-50 on it. Balanced @ 5" and all incidences are @ zero. I too had the same issues on knife edge. Either side knife edge tucked to the belly and rolled to upright. I ended up dialing it rudder to aileron, and rudder to elevator mixing. Works fine now, but spent a few flights one day setting the mixing up.
