New plane?
Well, I am looking for something to replace my morris hobbies .40-.46 _____ (I don't know what it was) that crashed.... I have an OS 40 SF and some Hitech servos from the morris. I am looking for something that the SF can haul around and is good for 3D. preferably with a built up fuse, but a profile is a possibility. It needs to be used, or else very cheap. (under $100) lwould like it to be an extra, but I am considereing a cap232 or some kind of bipe. Any suggestions?
I amthinking abouta sig somethin extra, do those 3d good?
FL
fused 3D that a os 40 will pull... boy .. oh boy your narrowing things down ....
http://www3.towerhobbies.com/cgi-bin...?&I=LXDUL8&P=0
just to lvl the playing field a 40 isn't goign to really Hover or have veritcail pull out on much .. I'd recommend the normal route small elctircs 3DHS extream flight ..
or if you budget minded I'd think about flying some larger foamy's out side if you worryed about incoutners with the ground ..
http://www.fancyfoam.com/index.php
EPP foam ..
