36-46% ultimates
I have seen the H9 and the Aeroworks big bipes do all most every thing! The only negative is Outside waterfalls, They will do inside very well. Both Airframes are very Strong. The wires on the AW work very well. The non wired H9 is also very strong. I saw Mike put his together in about 10-12 min. The AW goes together in about the same time. I'll see if I can get a pic of the Quick wire setup on the AW tomorrow.
One of the guys I fly with has the AW. I saw Mike McConnoville at the DOGS show in Dayton put the H9 through it's paces!
Mike flew the AW for my Friend from take off to landing! He said that they are basically the same! Down line's were identical!!!!
Also found out about the 46% and 42% thing between them. Mike said that they each used different documentation for the scales. The wing spans are different on the documents.
This is the really funny part. The AW wing is from one of Mikes early ones, and the removable tail on the H9 is almost the same one that Chip Hydes Dad designed for Chip!! Small world!
Later, Scott
Later, Scott
