Advice on smoke systems
I have a Hangar 9 Edge 540 and want to add a smoke system for some additional fun. I use a Moki 180 into a custom made muffler which uses a single tap for fuel pressurisation. Has anyone got any good suggestions for a set up which I can make?
Do an internet search for "megasmoke". its a great all in one unit, and you can contorl the pressure flow from the transmitter. They also have sell little smoke "injectors" for mufflers without smoke taps.
My Feedback: (33)
I have a (2) TME smoke system that I would sell you. This comes with pump, fuel line, check valve,copper line to put around the motor or on/in muffler(for pre heat) and the ele switch to hook into your rx(negitive shift). I also have a 3/4 gal smoke fluid and hand crank pump on it. Let me know if after your investigation you think you would like this.
Brandon
Respond using [email protected]
Brandon
I was just out at the field where i fly. I tested a smoke system i made, using it on my great planes super skybolt. It is powered by a Saito 100 Fa (nice engine) If you go to this site http://www.rcmodelers.com/INTRODUCT/...ntrosmoke.html[/L] there is a pressure system for smoke. It was easy to install, and it works extremly well. The smoke valve and check valve can be bought from Perry. You can use your flap nob on your transmitter (if you have one) to adjust the amount of smoke going into the engine. I highly recommend this setup!!
