 Do you know this plane? >
Old 09-24-2003 | 09:58 PM
Default Do you know this plane?
Hi all
I just acquired this model. Though it is listed as 3d plane given its aileron, elev, it fuse shaped almost pattern line. I'm sure it will knife edged well. It almost the same wing area as MAGIC 3D but it come with full symm airfoil instead of flatbottom.
Will fly it on TT Pro46.
Anyone know this plane?
http://www.gzmodel.net/ReadNews.asp?...&SpecialID=49
Old 09-24-2003 | 11:30 PM
aftcg's Avatar
Default RE: Do you know this plane?
The link didn't work for me.
Old 09-24-2003 | 11:36 PM
Default Re:do you know this plane?
me neither.
Old 09-25-2003 | 12:29 AM
hroachen's Avatar
Try this:
Old 09-25-2003 | 06:15 AM
Sprink's Avatar
It suggests a 36 size 2 stroke, so would think a 46 would be fine. Difficult to tell without the weight.
Elevators look a bit small, but that rudder doesn't look much bigger than that for a sport plane. Doesn't even have a counter balance.
Looks good though.
Old 09-25-2003 | 07:29 PM
AUW with engine about 4.5 lbs.
WHat is counter weight, Sprink?
The rudder is a bit small. The elevator actually big, almost same as the magic 3d.
This plane have 2 version, pattern and 3D hence the fuse shape. The tail similar to the pattern one with bigger rudder.
